Re: Super M carb rebuild, need small part
Posted by RustyFarmall on May 18, 2008 at 07:04:49 from (209.152.78.71):
In Reply to: Super M carb rebuild, need small part posted by Tom Fleming on May 18, 2008 at 03:10:55:
I think you are talking about that small spring and steel ball. I do not have any spares, but I will tell you that the vast majority of those choke detent check balls are missing and the small spring is either missing or severly rusted/stuck to the point of being totally non-functional. If you can find the parts you need, get them, but if you can't find them, don't worry about it too much. The choke control rod will keep everything in position.
