Re: Farmall cub coil leaks
Posted by old on May 18, 2008 at 10:23:07 from (4.245.6.23):
In Reply to: Farmall cub coil leaks posted by Buffc on May 18, 2008 at 07:26:30:
Leaky coil means a coil going bad. The oil in them do 2 things. #1 helps keep them cool and #2 insulation for the wires in it. Oil leaking means it shorts out as it get hot and when it shorts you then loose spark. Also when they start doing that I have seen them explode and bot what a mess when one does explode
