Re: B414 battery meltdown issue
Posted by supera2 on May 18, 2008 at 12:47:26 from (75.90.174.79):
In Reply to: B414 battery meltdown issue posted by Joe Brown on May 18, 2008 at 12:11:57:
My B-275 same as 414 has 2 6volt bat in series,12 volt. The glo plugs have a resister under the dash. The starter is the weak point on these tractors, 3 bushings back center and nose,the center bushing will cause a drag that overloads the cables. The tractor is worth fixing, It will run loaded all day on 10gal of fuel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
