As Red Dave said take apart the connections at the battery. clean with baking powder and a little water, just enough water to make a paste. Make sure all your connections are clean to include where the ground cable bolts to the frame. Tghten all connections good. If the battery connector terminals are bad replace them. You can get just the ends that clamp to the cable but I don`t like those because they corrode where they clamp to the cable. I always replace the complete cable
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
