Re: W6 Belt Pulley size?
Posted by Haas on May 18, 2008 at 18:19:50 from (12.65.30.221):
In Reply to: W6 Belt Pulley size? posted by bigr on May 18, 2008 at 06:15:40:
My 6 series parts catalog lists the 11 inch diameter by 7 1/2 inch face as the standard pulley for the W6. That is the same as the standard M pulley. There are 10 special pulley sizes listed from 6 1/2 inch diameter all the way up to 15 inch diameter. Most of the special ones have 8 1/2 inch face, but some have the 7 1/2 inch face. Several of them show to have 8 hole mounting. My catalog is dated 1947. What pulley you use depends on the pulley size on the implement and how fast the implement you are driving needs to run. So about any pulley size that fits on the flange can be called correct.
