Re: W6 question
Posted by Andy Motteberg on May 18, 2008 at 21:24:57 from (4.143.222.117):
In Reply to: W6 question posted by bigr on May 18, 2008 at 15:37:07:
That is not a water jacket on that side, it is the crankcase breather/push rod cover. If you remove the cover to fix the crack, open the breather and clean it.
Andy.
