Re: Firing order for an h with 12 V conver
Posted by Hugh Mackay on May 19, 2008 at 15:39:02 from (64.228.11.4):
In Reply to: Firing order for an h with 12 V conver posted by Luke in Ohio on May 19, 2008 at 15:28:18:
Luke: All Farmall engine start with No.1 being closest the radiator. From there it's 1 - 3 - 4 - 2. A different distributor or voltage can not change the firing order, that is predetermined by crankshaft and camshaft.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
