Re: Farmall A brakes
Posted by P and R Pete on May 19, 2008 at 17:47:51 from (159.240.11.254):
In Reply to: Farmall A brakes posted by Steve Schreppler on May 19, 2008 at 15:07:33:
Good timing. I was ready to post with the same questions. I have a Super-A, and I think I broke a brake band. The pedal bottoms out with no 'grab' at all.
I've been studying the sectional view in my I&T manual. Since the drum is pinned to the diff. shaft with a set screw, I'm supposing the differential shaft has to come out with the axle housing. I'm also supposing the 'how's' of getting at the seals will be self-evident once it's off.
My question- will I be extracting the drum from the center loop of the brake band, leaving the band behind with the tractor to be removed separately? Or does the band come out with the drum?
Tnanks
