dwsc, The spring has a long and short end. Hook the long end through a hole in the mechanism behind carburetor, it is at the highest point of the mechanism and the spring pulls forward to the post at front of engine. When it is in its proper position it will be in a flat line with the head gasket. The whole intake shaft rotates up for gas down for diesel. On the back side you will find a V shaped lever which is operated by a vertical linkage with a flat bar that fits in the V. Good luck, Chuck
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
