Re: 460 hydraulic pressure
Posted by rust collector on May 20, 2008 at 08:27:19 from (130.18.53.203):
In Reply to: 460 hydraulic pressure posted by Kinger79 on May 20, 2008 at 05:09:41:
You might consider replacing the rake cylinders with a larger bore piston. I would be concerned that increasing pressure much on a 460 might put more strain on the pump and a few seals than it would stand. Have you done a pressure check on the system to be sure it is up to spec? You could have a weak pump that shimming the relief would not help. 1600 psi seems like what I remember from a 560 system. Adding 200 psi may make internal leakage more excessive with little improvement.
