Re: 460 hydraulic pressure
Posted by Kinger79 on May 20, 2008 at 12:50:49 from (24.25.175.98):
In Reply to: 460 hydraulic pressure posted by Kinger79 on May 20, 2008 at 05:09:41:
I shimmed with two 3/8 washers and only got about 1400 psi, seems awful low to me. It is a brand new pump. everything else in pressure relief seems cherry. maybe have a weak spring. or are leaking by somewhere else
