The starter drive gear and/or the teeth on the flywheel are worn. You might try a new drive gear, that is the simplist, otherwise you need a new ring gear, which will require splitting the tractor. To limp along, loosen the starter, and move the tractor manually a little -- has the same effect as putting it in 5th. You can also jack one rear wheel up and try to turn the wheel while in 5th -- easier than pushing the whole tractor. Starter or solenoid could be shot, but I doubt it. Try the other things first.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
