Re: Low Hydraulic Pressure 1086 - Pump or Relief Valve?
Posted by the tractor vet on May 21, 2008 at 07:36:49 from (76.212.234.130):
In Reply to: Low Hydraulic Pressure 1086 - Pump or Relief Valve? posted by cgustafs on May 20, 2008 at 19:05:32:
The best way is to have the tractor Flow Rated . As on the 86 seires depending on the year there was two different systems . Having the flow rate done can save time and money as this will nail done the problem . But for most people this means having a dealer or a good repair shop do the testing and the flow rater is not something that you are going to run out and by for a one time test .
