Re: Farmall H fan belt tension
Posted by Janicholson on May 21, 2008 at 16:14:28 from (64.83.197.92):
In Reply to: Farmall H fan belt tension posted by kippster on May 21, 2008 at 11:10:24:
I'll add to Rootsy's correct info, that the belt does not, and should not be very tight. If you can push it an inch with your thumb, it is A-OK. Too tight, and things (waterpump) wear out. It is a loose still does not slip kinda thing. JimN
