Metal to metal contact.
Posted by usetabesteve on May 22, 2008 at 05:16:06 from (205.240.41.69):
In Reply to: Re: farmall h governor posted by bgarrett on May 22, 2008 at 04:35:23:
Even with lubricant, the parts will wear. When there is enough wear to make some slack in the mechanism, you get that draggy feeling. Springs lose their tension as well, and sometimes break. You have to take it out, look it over, replace the spring, and replace the worn bits.
