Posted by Bob M on May 22, 2008 at 12:53:43 from (151.190.254.108):
In Reply to: CUB WIRING posted by S/C BOB on May 22, 2008 at 09:53:06:
Gotta be either it's wired up wrong or the cutout relay in the voltage regulator has stuck closed.
First double and triple check your wiring - make sure all the connections are made to the proper terminals. Also make sure there are no accidental grounds. Pay particular attention to the wire between the voltage regulator BAT terminal and the ammeter. (Also if your Cub has lights check the supply wire to the light switch....)
If you find no errors or grounds, next temporarily disconnect the wire from the GEN terminal at the regulator. Now try reconnecting the wire at the ammeter. If you still get fireworks the problem is a bad voltage regulator - time for new one.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
