Posted by garytomaszewski on May 22, 2008 at 20:34:23 from (4.158.174.150):
In Reply to: Re: F-12 posted by Coax on May 22, 2008 at 20:04:00:
No pressure in the system, if this is a "play" tractor almost any kind of patch will hold. Try making a plug exactly the same size as the hole then weld a piece 1/2" larger (all sides) to it JB the 1/ 2" flange slap in the hole and go. Could even tap and put screws in the corners.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
