Re: 686 Loader Control Valve
Posted by ih560 on May 23, 2008 at 06:36:12 from (204.118.68.33):
In Reply to: 686 Loader Control Valve posted by gp on May 23, 2008 at 06:09:56:
If you want to free up at least one remote, you could use one of them to feed an open center 2 axis joystick. You could then leave the remote locked in position and feed the joystick to run both functions of the loader. If you are going to to do it this way you need the open center joystick. If you want both remotes free, plumb it into a supply line before the remotes and use a closed center joystick, run the return line from your joystick to a port on the rear end somewhere and then you would have both remote free.
