Re: Farmall h generator troubles
Posted by Nebraska Cowman on May 23, 2008 at 07:30:05 from (65.165.16.237):
In Reply to: farmall h generator troubles posted by wellsy on May 23, 2008 at 07:13:57:
Right. The Fields ground through a resister to "regulate" the charge. Grounding the field terminal directly results in full charge all the time. For occasional use tractor or winter use that's what I do. Just use a jumper wire and if the think the battery is being overcharged unhook it for a while.
