Wellsy - Even if the resistor has failed the generator should still charge hard with the light switch set to the "H" position.
Most likely the ammeter box cover - and thus the switch - is not grounding to the tractor frame. Another possibility (long-shot...) is the LHDB switch has failed.
Tip - If you run your tractor a lot replace the cutout and manual control with a voltage regulator! It'll solve your field grounding problem. Also it will do a better job keeping the battery charged (and not overcharging....) than you can ever do with the manual control.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
