Posted by Athol Carr on May 23, 2008 at 15:39:01 from (219.89.30.29):
In Reply to: F-12 posted by Coax on May 22, 2008 at 19:41:52:
The F-12 engine has a weakness in the bottom of the water jacket above the fuel pump. My O-12 had a crack there, it did not leak but was noticeable. I had the block stripped, took three sessions in a hot-tank to get the sleeves out, and the crack welded. You have to look very hard to see it now. I have seen lots of patched blocks, one with a copper plate riveted on. A ready supply of anti-freeze in the old days might have been useful. The engines have one other fault, the push-rods did not allow the spark plugs to fit between them so they are on the other side of the engine under the manifold where they are hard to get at, ordinary plug wrenches will not fit and they had to use a down-draft carburettor with its fuel pump. This is fine once started but unless one has the starter tank above the engine (only on kerosene or distillate) with its gravity feed, if they have been sitting for a while it takes a lot of cranking to get the carburettor full of fuel so the engine can start. The engine is 113 cubic inch but was not the same as the C113 engines in the Farmall A etc. I believe the pistons and sleeves from a Farmall A can be fitted but the bottoms of the sleeves need some modification
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
