I need help before I cause another $1000 in damage!!
Posted by Butch WI on May 23, 2008 at 18:41:59 from (69.19.14.23):
Earlier this spring I was plowing with my 460 U when I lifted the plow and part of the fast hitch busted off the shaft that turns on the PTO, flush with the housing!! How do I get this heavy SOB back into the opening? I have the top 2 bolts (circled) started in the threads. Note the gap to close (in the oval circle.) The bottom 2 bolts (arrows pointed to them) are not yet started! I don't want to turn the top ones in for fear of not getting the PTO unit in squarely Any one have any Ideas? When I removed it I pulled on the shaft and wiggled all directions ALOT! until it came out. What are the chances that the splined coupler inside is not lined up? Here is a photo I hope...
If it doesn't show up it is in the Parts & pieces area.
[img]http://www.tractorshed.com/gallery/pieces/v5376.jpg
[/img]
Thanks
Hope to see some of you at RPRU!!!
Butch
