Re: hotrodding the Model H
Posted by ChadS on May 23, 2008 at 18:48:01 from (4.224.78.139):
In Reply to: Re: hotrodding the Model H posted by ChadS on May 23, 2008 at 18:35:46:
One thing to remember, this is a Farmall H tractor,, and overloading the chassis for beyond its reason for working conditions are not recommended. For example, trying to pull a 6 bottom plow with a farmall H, or Weighting one up to 7500#'s to go pulling, its not what it was designed for. Treat it just like you would your everyday workhorse, and it will run as long as you take care of it. I run mine on both spectrums,, work and play, so far, Ive had real good results with some research, hard work, and good parts.
