Re: well durn that 230 is slowwwwwww
Posted by Hugh MacKay on May 23, 2008 at 19:03:25 from (209.226.106.188):
In Reply to: well durn that 230 is slowwwwwww posted by tn terry t on May 23, 2008 at 18:00:05:
Terry: you put 9.5x24 on the 140 and 11.2x36 on the 230 and they will be very close to each other in top speed. You put 12.4x24 on a 140 and it will out run just about any factory tractor up to 1970. 12.4 tire is about 6" taller than 9.5.
Another factor that can make some of these faster is someone tampering with the governors.
