Re: Extra lever on M
Posted by Haas on May 24, 2008 at 18:02:18 from (12.65.12.11):
In Reply to: Extra lever on M posted by Dr. Bert on May 24, 2008 at 15:00:57:
As Bill said, sounds like an M&W 9 speed setup. It is a 2 speed setup that gives you two speeds in gears 1-4. Does not affect 5 as that is direct drive. The extra speeds are faster than the original speed in each gear. The set up also affects the PTO, as when in the high speed range, the PTO also turns faster.
