Re: Extra lever on M
Posted by D Slater on May 24, 2008 at 18:32:07 from (71.164.55.219):
In Reply to: Extra lever on M posted by Dr. Bert on May 24, 2008 at 15:00:57:
If its on the left when seated on tractor, that is the shifter location for a hiesler 9 speed set up. But if thats what it is the linkage and shaft should go in side of transmission behind torque tube. You may have a aftermarket hydraulic pump drive disconnect if linkage goes ahead of transmission. Also some M&W 9 speeds that were cable shift ended up with owner modified shifting that still used the bolt hole in front of transmission case for transmission entry.
