Re: 1086 TA / Clutch
Posted by bemhoff on May 24, 2008 at 20:13:28 from (98.21.93.215):
In Reply to: Re: 1086 TA / Clutch posted by Kevin Meier on May 24, 2008 at 19:46:44:
Kevin, thanks for your reply. What all does the pump supply fluid to? I had shifted the TA a few times after I first heard the noise and had no issues and also depressed the clutch several times and it seemed fine. All of this was at higher 1800 RPM. Does the MCV pump supply fluid to the TA and also have something to do with the clutch? Don't know a lot about these bigger tractors. Have a 766 and this 1086, both bought in the last 4 years. We just do small time hobby farming, maybe put 100 hrs on each machine a year so I have little trouble shooting experience on them. Again, Thanks
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
