Re: Farmall A brakes...
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Farmer Bob on March 11, 2000 at 20:30:23 from (207.227.187.190):
In Reply to: Farmall A brakes... posted by Fm on March 11, 2000 at 16:41:49:
FM, Sounds like a mechanical failure with the left brake. Remove the final drive and check the band and drum. You may find no band and the rivots that used to hold the lining on the band are making grooves in the drum. If that's the case, you'll have to remove the drum from the axle and have it turned. May just as well check the right one at the same time as it may save you from a disaster later while pulling those 100 bale loads of hay.//FB
Post A Followup
: Re: Re: Farmall A brakes...
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
