Re: 140 sway bar
Posted by Janicholson on May 25, 2008 at 10:02:28 from (64.83.197.92):
In Reply to: 140 sway bar posted by cris on May 24, 2008 at 07:13:59:
If it is not a fast hitch planter, the sway bar should have a pin/bolt hole in it locking the sway motion. If it is a FH planter, listen to what Hugh said. JimN
