Re: IH 674 Clutch/Trasmission Issues
Posted by caterpillar guy on May 25, 2008 at 10:57:07 from (64.12.116.73):
In Reply to: IH 674 Clutch/Trasmission Issues posted by Reddog176 on May 25, 2008 at 10:49:45:
Yes the main seal is out in the engine or transmission you will have to split the tractor and replace the seal if it is red color trans if black engine if just chunky just grease from throwout bearing and pivot shaft. those are a metallic clutch disk there is a fiber option for them now I believe. you might try to adjust the linkage on the pedal first. If there is no free play in the pedal or the easy part of the travel is gone.
