Re: 1942 H questions
Posted by edward_m on May 25, 2008 at 22:11:38 from (207.199.239.174):
In Reply to: Re: 1942 H questions posted by RedJohn-2 on May 25, 2008 at 18:56:44:
...and make sure the ground is under the bolt that holds the starter in place.
I've seen some with the ground attached to the frame, and it seems it always causes trouble.
Also, if you try and jump direct to the starter with the battery and it still won't start, its possible that your starter picked this as an opportune time to fail. It could still be wiring (especially from your description), but you might want to pull it and have it checked.
Good luck.
