Posted by Dave BN on May 25, 2008 at 23:07:54 from (205.188.116.73):
In Reply to: Cub stops running posted by John A. Halford on May 25, 2008 at 22:54:55:
Gas in the tank does not mean gas is getting to the carburetor. Check for rust, scale or dirt in the tank, sediment bulb and fuel line. Obstructed fuel system often allows a small amount of gas to flow but not enough to keep the engine running. After sitting for a few minutes enough gas has flowed back into the carburetor to allow the engine to run for a short time. Or you could have a bad coil causing you to loose spark when hot. Try checking for spark when the engine quits. Dave
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
