Re: Cub stops running
Posted by james rumph on May 26, 2008 at 04:38:14 from (24.192.124.16):
In Reply to: Cub stops running posted by John A. Halford on May 25, 2008 at 22:54:55:
If there is also a fuel filter get rid of it, automotive fuel filters are designed to work with fuel presure not gravity.
Also" maybe" retorque the head " loss of compression" was it leaking coolent or burning it ?
Does your carb have the factory screen filter in it right ware the fuel enters the carb "plugged" ?
I have seen ware the condensor in the dist. was bad when it got warm "no spark" !
Just throwing some ideas out that i have seen with cubs , hope one helps.
