Posted by J.J. from Afton on May 26, 2008 at 08:10:53 from (66.41.82.17):
In Reply to: janicholson please posted by Dylan Nichols on May 25, 2008 at 23:20:32:
Here are some pics from when I redid the brakes on my 560. They are same thing, just a little bigger. Mine were so bad on both sides tht I had to turn the two sides of the expander and the housing castings in a lathe to get a smooth surfce again. Only difference between these and the ones on your 340 is size, for example 560 expanders have 5 ramps and balls, where 340s only have 3. Use a large screwdriver or pliers to pry the springs of the expanders being careful not to ruin them, unless your already planning to replace them. Than clean out all the ramps with a wire brush to remove any rust, dirt, etc. Also if the balls are pitted or worn real bad you just as well replace them. Once its all cleaned up put em back together and reinstall the springs. Also be sure the housings are still relatively smooth/evenly worn. And if you do need to replace the disks it is best to get them trhough a CaseIH dealer, better quality, longer life.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father.
... [Read Article]
Latest Ad:
[More Ads]
