Re: Farmall B - Light dimmer coil
Posted by Bob on May 26, 2008 at 11:24:39 from (69.178.228.68):
In Reply to: Farmall B - Light dimmer coil posted by Dave H (MI) on May 26, 2008 at 10:39:35:
A dimming resistor works by converting excess electrical energy to heat.
Dimmer resistors simply get HOT. Always have, always will!
I can see there MAY be an issue depending upon the wattage draw of the 12-Volt lamps vs. the original 6-Volt lamps, however those resistors ALWAYS did get hot. They are wrapped in an asbestos or other fiber wrap, which should NOT be burning off, no matter what. HOWEVER, there may by oily residue on there, from your fingers, etc, that IS smoking as it burns off.
