Re: Farmall 400 won't start
Posted by Dan Anderson on May 26, 2008 at 14:44:28 from (75.81.114.131):
In Reply to: Re: Farmall 400 won't start posted by El Toro on May 26, 2008 at 13:34:38:
I have 12 volts at the starter. I did not try
shorting across the solinoid. Does the key need to be un RUN position?
If the alternator is shot, will that keep the tractor from starting?
I checked cables, and I cant find any problems at the battery or battery box (ground).
