Re: Cub stops running
Posted by Brownie 450 on May 26, 2008 at 17:43:06 from (216.51.158.151):
In Reply to: Cub stops running posted by John A. Halford on May 25, 2008 at 22:54:55:
Our MTA had problems similar to what yours sound like. Turned out to be the wire to the coil was down to 2 or 3 strands where it had flexed many times--got hot after running awhile--resistance went up--tractor stopped. Check with an auxiliary wire from the hot terminal on the battery when it quits[alligator clips on ends]. Otherwise probably fuel or points/ cond as the others have noted.
