Re: Farmall 400 won't start
Posted by IntHarv on May 26, 2008 at 21:14:05 from (69.27.61.226):
In Reply to: Farmall 400 won't start posted by Dan Anderson on May 26, 2008 at 11:43:31:
You could also bypass everthing and apply jumpers to the starter itself. Make sure tractor battery is disconnected. Connect positive from jumper on the starters hot termial and negative on a chassis ground. The starter should engage and if nothing else is wrong it should start. As always out of gear with brakes. If it does start test your solenoid as described before. If it checks out check wiring and connections to and from the starter switch.
How long has the tractor sat?
