Re: 1946 Farmall A High Speed
Posted by ShaggyM on May 26, 2008 at 21:16:19 from (12.208.47.240):
In Reply to: 1946 Farmall A High Speed posted by tdudley on May 26, 2008 at 18:35:56:
The engine speed is 1540 with no load. If you look at the gov housing (just north of the Distributor or mag) you will see a bolt with a jam nut. If you turn the bolt out you will gain rpms.
Hope this helps.
Shaggy
