Re: How to free up cluch?
Posted by Don L C on May 27, 2008 at 09:32:23 from (24.166.246.180):
In Reply to: How to free up cluch? posted by Bill Thompson on May 27, 2008 at 07:32:37:
The way to get it un-stuck is to shock it loose...get it out in a rough field,you would need to pull start it with another tractor......F-20 ,no starter right.....
with the F-20 in a high gear = more shock....holding the clutch in ...pull start it with other tractor...after F-20 starts keep the front tractor and chain loose but out of the way of the F-20.....drive over rough ground (plow furrows) until clutch breaks loose.....
rember if it does not break loose and you must stop shut F-20 engine off first.....
