Re: Voltage regulator Bob M and/or others
Posted by Bob M on May 27, 2008 at 10:45:49 from (151.190.254.108):
In Reply to: Re: Voltage regulator Bob M and/or others posted by Janicholson on May 27, 2008 at 10:31:44:
Good advice Jim! A reading of anything greater than 6.6 volts on an idle 6 volt battery would make me suspicious of the voltmeter calibration.
Also unless you've got a high quality, industrial grade digital voltmeter you are better off with an analog multimeter when working with old tractor electrics. The transients and noise from generator commutators and vibrating relay regulators can drive low-end digital meters to wildly erroneous readings.
