ghouse: If you could pull the 13' disk the depth of cut would be such you mat as well be pulling a land roller. If the 13' disk is the righr price, why not cut it down to 8'. You'd have lots of spare blades, scrapers, probably 4 spare bearings plus aome decent steel.
I had an 8' Oliver that could make my Farmall 300 sweat and that was 1958, 300 was still quite new back then.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
