Posted by J in PA on May 27, 2008 at 12:42:31 from (24.239.59.159):
In Reply to: 404 hydraulics posted by EdB on May 26, 2008 at 14:46:15:
i wouldnt run it until you get a filter and screen for it.the pump may burn up. and when you put the filter in, fill the canister with hy-tran then put it on. theres a small 1/4"square plug on the left rear side to check the fluid level. hope this helps a bit.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
