Posted by M Lake on May 27, 2008 at 18:24:24 from (64.228.3.8):
In Reply to: Farmall Oil question posted by charley123 on May 27, 2008 at 12:25:38:
Diesel or Heavy duty engine oil such as Rotella will loosen crud and clean. I know from a Tempo that had so much crap in it that the pick up screen plugged after changing oil ---no oil pressure. That is why Rotella will tell you to stay with straight 30 w so not to cause seal leaks and such.We own a 52 W4,52 W6, 52 Super W6and a 53 Super WD6 that run Rotella with NO problems.Personaly,I say no mystery oils just change oil more often for a while till the black is gone
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
