Smith1000 said: (quoted from post at 18:47:25 05/27/08) What causes the gears to want to grind a bit when shifting? It has always done this, unless I idle very slow and move it into the next gear very, very slowly. Otherwise, I can start out in a higher gear. Kind of would like to fix it. Any ideas on what might be the solution?
You can't shift while moveing without the gears grinding somewhat. The transmission is a sliding gear trannsmission, when you move the shifter lever you are actually sliding a gear into mesh with another gear. The two gears have to be turning the same speed for them to mesh smoothly without grinding, this takes practise.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
