Re: Super M Gears Grinding?
Posted by ScottyHOMEy on May 27, 2008 at 19:07:31 from (70.105.254.77):
In Reply to: Super M Gears Grinding? posted by Smith1000 on May 27, 2008 at 18:47:25:
Basic idea is that if the tractor is idling in neutral with your foot off the clutch, the input shaft is turning. It has some momentum to it, so it won't stop turning immediately when you depress the clutch pedal. If you try to shift it into gear before it's stopped spinning, you'll get a little grinding. The gears are a straight cut so they'll be a little noisier as they mesh. Doesn't happen every time by any means, but being a straight cut, you'll also be more apt to find, if you wait and let the input shaft spin down to a stop, that they don't mesh as easily, as is in you might have to let up a little on the clutch to spin and crunch it into gear.
What's synchro-mesh?
Nature of the beast.
