Re: Generator charging rate
Posted by Bob M on May 27, 2008 at 19:38:48 from (69.205.114.144):
In Reply to: Generator charging rate posted by Dr. Bert on May 27, 2008 at 18:40:43:
You have (2) problems Doctor:
1 - The field resistor on the light switch has failed. This will cause the generator stop charging with the switch in the "L" position. Replacing the resistor should solve the problem. (Unfortunately I cannot recall the correct resistance - seems to me it's about 5 ohms but I'm uncertain...)
2 - The 3rd brush in the generator needs to be adjusted to reduce the maximum charging rate to 15 amps or so. (Rotating the brush AWAY from it's nearest neighbor reduces the charge rate.)
Alternatively you can abandon the manual charge control and cutout relay and replace it with a voltage regulator. A VR will automatically limit the maximum charge rate to a safe 15 amps or so. Also it will do a better job keeping the battery charged.
Note! With a regulator installed the L and H positions on the light switch simply become 2 "off" positions for the lights.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
