Re: h farmall steering
Posted by Bob M on May 28, 2008 at 09:38:10 from (151.190.254.108):
In Reply to: h farmall steering posted by donald schnupper on May 28, 2008 at 07:11:38:
Don - Before you spend lotsa $$$ for new worm or gear, determine exactly where the steering slop is coming from!
With the steering gearbox cover removed, rock the steering wheel shaft left and right and look for play at:
- Bolster pivot shaft (the vertical shaft with the sector gear at the top). ANY left/right and fore/aft movement of the shaft means the pivot shaft bushings (possibly also the shaft) are worn out.
- Steering worm ball bearing and bushing. Any fore/aft movement of the worm means the ball bearing is worn out. Lateral movement of the worm the bushing end says the bushing is bad.
- Backlash (free play) between the worm and gear means the worn gear (usually...sometimes also the worm itself is worn). Also a sloppy upper pivot shaft bushing will cause excessive worm backlash even with good worm and gear.
Generally it's a combination of worn parts causing steering slop. But simply replacing the worm and/or gear may not make the steering any better.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
