Re: Farmall H no power
Posted by Allan In NE on May 28, 2008 at 14:28:32 from (148.78.243.26):
In Reply to: Re: Farmall H no power posted by lbm on May 28, 2008 at 14:24:40:
The rubbing block up on the high side of the cam?
If not, rotate the engine a bit with the fan blade until the points break.
Allan
