Re: HELP?
Posted by JimB2 on May 28, 2008 at 16:43:02 from (99.241.179.24):
In Reply to: HELP? posted by Allan In NE on May 27, 2008 at 17:17:46:
Allan, nice swather. My brother has D239 in his 684 and has over 8,000 hrs on it and still running good. As for starting it is harder to start than his D206 or D179 but with a sniff of ether it will start to about 10F and below that he uses the recirculation block heater for about an hour and no problems. It should have a START position on the STOP/RUN control. You would not be swathing in that cool of temperature.
D239 is economical to run, the most we ever used was about 2 US gal/hr chopping corn silage and that was with the pump turned up to about 70 PTO HP. After we finished chopping corn then we would turn pump back to normal.
JimB
